multiply and negative displacement
  • multiply and negative displacement
    looks like vray wont read negative values in a dispmap if i use a composite node to combine two maps...
    https://linktr.ee/cg_oglu
    Ryzen 5950, Geforce 3060, 128GB ram
    disp_test.rar here the maya file...
      Try setting explicit displacement bounds in the "Displacement control" extra attributes to the displacement node. When the texture is not directly passed from a file but goes through other nodes (incl. if it's a sequence or uses texture tile tags like UDIM/UVTILE) V-Ray is not able to automatically compute the bounds and it's necessary to set them explicitly especially when there's negative values. Try settings something like -5 to +5 and see if it helps. Btw, since Maya 2016 (I think) the HSV color picker does not allow negative values, so you'll need to switch to RGB 0-1 and set the negative minimum value for R, G and B.
      Alex Yolov
      Product Manager
      V-Ray for Maya, Chaos Player
      www.chaos.com
        thanks that does work...
