VFB right click select Material not working properly
  • VFB right click select Material not working properly
    Win 10, Maya 2017 Update 3, Vray build adv_36002_maya2017_x64_27734
    In IPR, it seems that if a Vray Rect light is between the render camera and the object, I can't select the object or material in VFB.
    Sometimes, I get the light that is between render camera and the object selected. Sometimes, I get nothing selected (Attribute Editor has no response when I click around). As soon as I zoom in on the render camera in viewport (so that the render camera has passed the inbetween big Rect light), I can select the object/material in VFB again.
    Thanks,
    Jason
    always curious...
    Hi Jason,
    This is with light set to Invisible mode right? I see that our devs are working on solution for this problem.
    Tashko Zashev | chaos.com
      tashko.zashev if you mean the invisible flag of the light, then yes, the light is set to invisible. The same for most of the lights in the scene.
      always curious...
