Vrscene vs Vrmesh & Opensubdiv?
  • Vrscene vs Vrmesh & Opensubdiv?
    Hi All,
    Playing with VRay proxy objects and am running into some issues that I'd love a sanity check on:
    My goal is to get matching renders from our maya meshes through to the rendered proxy object. (vrmesh / vrscene). In our pipe we're currently using opensubdiv on our meshes to allow for crease sets etc.
    1) It appears .vrmesh doesn't support open subdiv? (either by vray attribute on shape or on a vrayDisplacement node)
    2) vrscene files don't have the same controls as a vrmesh (ex: hiding a contained object or adjusting a material - *I'm aware you can write the .vrscene to separate files and modify shader values directly), but I can't see a way to do so in scene
    Is there a recommended workflow to deal with assets through to a proxy object?
    I've attached a .zip of the materials to generate the image below (.ma with mesh, .vrscene and .vrmesh generated from the mesh)
    Thanks
    -Richard
    Thank you for the provided files in details. Currently the .vrmesh does not support open subdiv indeed. I would discuss this our with our Dev Team.
    I guess that it would be best if you could set you creases, open subdivs, materials and use the .vrscene as a way to optimize your scene assets. At this point it is possible to make override certain parameters using the Scene Override atribute.
    You could find some example code lines to alter the V-Ray scene on the following page:
    https://www.chaosgroup.com/blog/how-...n-applications
    Click image for larger version  Name:	2017-11-02_17-01-29.jpg Views:	1 Size:	35.6 KB ID:	973090
    Nikolay Kusht | chaos.com
    Team Lead, 3D Support | contact us
      Thanks for looking into this Nikolay, I will investigate .vscene further using the scene override attributes
      Thanks
      -Richard
        Hi all,
        I see that this message is quite old but it seems that it is still not supported (open subdiv/vrmesh) in the version we're using(4.12.01). Am i right? Is there a work around for it? We use crease edges in modeling that we'd like to keep further in our vrmesh pipe.
        Thanks,
        carine
          This feature is still not supported for vrmesh. I don't think there is a workaround besides using the vrscene files.
            Sorry for resurrecting this thread but Im looking for possible solutions for our pipeline.
            Does anybody knows how is the last example on the image achieved, the one with VRmesh vrsubdiv. Is it just put inside a GeomStaticSmoothedMesh?
              Just select the shape node of your object and add V-Ray Subdivision Attribute. You could get more details here:
              https://docs.chaosgroup.com/display/...esh+Attributes
