Discrepancies in renders at different resolutions
  • Discrepancies in renders at different resolutions
    Hi Guys,
    I'm seeing some discrepancies on my renders when I render high resolution still images. Here is a test scene, one screenshot is 350 the other is 10% bigger 3500 and you can see that the render looks difference on the reflections. Just in case this happens with any kind of 10% on resolution. Btw all this is CPU btw
    Is this the expected behavior or am I missing something here?
    Maya 2018.1
    Vray 3.6.02
    To get the same results at 10% resolution, you can set the bump delta scale of the reflection bump to 10% as well (0.1).
      We might look into scaling the bump delta automatically with the resolution for future builds...
        Thank You both. Yes that fixed, it would be great if that the delta scale could be automatically. It can become a little a annoying changing all the time when doing test render at lower resolutions. I know that I could probably do a layer override, but still it should be automatically. Thank You again.
