Banding with very small light source
  • Banding with very small light source
ID:	973223 I'm getting severe banding when using a very small very bright light source. Is there a setting I'm overlooking that can resolve the issue?
    The attached image was created by placing a single VRayLightRect above a plane. All sampling is VRay default.
    Maya 2018, V-Ray 3.60.01, Windows7
    Troy Davis
    Animation Director
    atomicpictures.com
    This is actually a known issue of the V-Ray Frame buffer winch doesn't apply any dithering to the rendered image. Saving the image to a 32 bit file and opening it in Nuke for an example will give you the right look of the render.
    Tashko Zashev | chaos.com
      Or simply roll the mouse over the values, and you will see that while the Display shows banding, the values are continuous, not stepped.
      Lele
      emanuele.lecchi@chaos.com
      Disclaimer:
