Distribute and the new Camera overscan
  • Distribute and the new Camera overscan
    Distribute and the new Camera overscan does strange things...
    all slaves does render without the overscan..
    is there a workaround.?
    https://linktr.ee/cg_oglu
    Ryzen 5950, Geforce 3060, 128GB ram
    What V-Ray and Maya versions are you using? Is there a chance that your render slaves use an older V-Ray version that doesn't support overscan?
    Alex Yolov
    Product Manager
    V-Ray for Maya, Chaos Player
    www.chaos.com
      i dont think so...
      maya 2018.1
      vray 3.6.01
      will check again
        installed same versions on two nodes... still broken... the slave does not render with the overscan...
          I've mislead you a bit, sorry about that. This is a known issue - the overscan doesn't work in DR with our current 3.6 code base. It will be fixed for a future version, since it requires some bigger changes in VRay.
          Alex Yolov
          Product Manager
          www.chaos.com
            thanks for info...
              i bump this issue here... we cant work without the new overscan feature... its essential...
                It's already fixed in our internal builds, but will go out with the next major version of V-Ray for Maya, since the fix includes a lot of other changes to DR that are not safe to move to 3.6.
                Alex Yolov
                Product Manager
                www.chaos.com
                  thanks for info yolov...
