Stable build release notes not updated for a while
  • Stable build release notes not updated for a while
    Just wanted to check if there's a better way to see what's been added to a stable build. I just checked the release notes text file in these two, but they seem identical:
    release_notes_27878.rar 14 KB 03 Dec 04:32
    release_notes_27844.rar 14 KB 17 Nov 04:36
    Best Regards,
    Fredrik
    I've also mentioned the same as a footnote in another thread.
    As far as I can see, the release notes has not really been updated since sometime before the 3.6002 release.
    Previously I've often done a diff on the release notes once in a while to check upcoming fixes and so forth.
      Thanks for the pointer, the release notes should work properly from the next nightly build.
      V-Ray for Maya dev team lead
        Ok! Thanks Mihail.
        Best Regards,
        Fredrik
          And I can confirm that it works, tonne of new updates in the latest build from yesterday.
          Was looking suspicious for a while there.
          Thanks Mihail
            Hi Guys.
            Just a followup/heads-up on this.
            So the notes were fixed for the nightlies, but then I guess it also became a bit of a mute point since no more nightlies have been generated since that day?
              There are no other builds in the Stable nightly branch because there are no updates in the code yet.
                Ahh, that does make much sense then.
                Just wanted to check if it was an automated build issue and you guys had not noticed.
                There has been gaps in nightly builds in the past, but when I looked down though the dates it was never more than a few days.
                So I figured i would give you a heads up just in case
                Thanks,
                Jimmi
