Stereo Camera DR render not supported?
  • Stereo Camera DR render not supported?
    Am I correct in assuming from the crazy bucket errors I'm getting, that Stereo Camera rendering is not supported by DR?
    It's working fine here. What are your V-Ray/Maya versions and can you share the scene and a screenshot of the issue to support@chaosgroup.com?
    Miroslav Ivanov
    Chaos Cosmos
      Hi, back on this project again. Whenever I enable DR, I get this. It's hard to tell exactly what it's doing here? I've attached an image with and without DR turned on, I can break the scene down if needed, it's quite complicated.
        Could you please let us know what Maya and V-Ray versions you're using? Also, could you check if the DR machines use the same version of V-Ray, this may happen if there's a version mismatch.
        It would also be of great help in figuring out what the problem is if you could send a scene for investigation to our support team, like Miroslav suggested.
        Thanks.
        Alex Yolov
        Product Manager
        V-Ray for Maya, Chaos Player
        www.chaos.com
