Triplanar error
  • Triplanar error
    Latest build Maya version 3.60.04, revision 27959 triplanar (same texture on all axes) not working correctly
    Also Vray not loading render presets saved in Maya presets folder .json
    Maya 2018 windows 7
    https://www.artstation.com/damaggio
    It is normal for the X and Y axes to be in the same plain orientation. You can easily rotate those maps with the Texture rotation option anyway: https://docs.chaosgroup.com/display/...nar-Parameters
    Furthermore I can't reproduce the preset issue. Which V-Ray settings parameters did you changed? Can you provide a steps to reproduce it?
      Hi Zdravko, thanks for the triplanar tip, I was under the impression that the texture would be placed in the same direction as a Maya projection node >triplanar...it is working fine
      now following your suggestion.
      I was able to save new presets this morning, I don't know why I was having troubles last night.
      All fine now, thank you very much.
