Light texture not rendering in Specular channel
  • Light texture not rendering in Specular channel
    The lights in the scene with .exrs in the 'Use Rect Texture' are not showing up/rendering in the Specular channel.
    Refreshing the link works in the IPR, but then on re-rendering the lights do not show up.
    Reloading the links work in the IPR, but then not in the production renderer.
    All lights without a texture render ok in the Specular.
    I've tried .exr. and .hdr
    Put in a standard V-Ray light and this has the same issue - shows in IPR, but not in render.
      Everything seems to work fine on a simple scene. Could you please attach an example file and give us some steps to reproduce the issue?
        Hi Zdravko
        I've dropped on the beauty for the part I need, for now.
        I'll pm a file shortly.
        Cheers
