Multi UV Sets
  • Multi UV Sets
    Hello
    I am trying to use a different UV set on the bump map as on the other maps
    doing this with the "UV linking editor" doesn't seem to supporterd for vray
    as you can see a blinn shader gives options for the two connected materials
    the vray shader only displays he bump map, and not the reflection gloss (file connected)
    thnx in advance
    Martin
    just found it!
    the vray extra attribute in the "place2dTexture" node does the trick
      Hmm, the UV Linker should work just fine. Maybe you've come across a case where it fails. Could you share more details on the setup?
      But generally, the extra attributes where you can specify a UV set name does exactly that - ignores the UV Linking and uses the set with the specified name.
      Alex Yolov
      Product Manager
      V-Ray for Maya, Chaos Player
      www.chaos.com
