Last version Vray-Maya 3.6004 and maya 2018 , crashes when using VrayPhysical camera and tweaking parameters.
  • Last version Vray-Maya 3.6004 and maya 2018 , crashes when using VrayPhysical camera and tweaking parameters.
    Hi VrayTeam,
    lots of crashes , can?t send you send scene but would be good you to try it , using GPU crashes when tweaking Physical Camera parameters in real-time , I have a 2 GTX1070i , Maya 2018.1 and Win 7.
    I have never seen Vray crashing this way after more than almost 10 years of using it.
    Can you check it please?
    Thanks.
    Alex
    thank you for your feedback. I've tried to reproduce the crashes on simple and on a production scene but without success. Can you please give us some more information like do you have some extra attributes to the camera, the GPU driver version and some general information about what do you have in the scene (proxies, animation, MASH etc.)?
    Ivan Shaykov
    chaos.com
      Also, sharing the logs from V-Ray could point us in the right direction. Look for vray4maya_log.txt in your user's temp directory. On windows, you can just type %temp% in your windows explorer as a shortcut (with the percent signs). If possible, increase the verbosity to the highest level, then if Maya crashes again, send us the log (in render settings > setting > system > log message level = all messages).
      Alex Yolov
      Product Manager
      V-Ray for Maya, Chaos Player
      www.chaos.com
        Ok Alex , yes sure will do once it crashes again i will sent the log to you. Thanks. Alex
