VFB region render saving problem
  • VFB region render saving problem
    I have a problem saving EXR images from the VFB when I used region render. Since vray version 36003 it only saves the region instead of the whole image when I use the EXR format. It still works fine with other formats. Same problem with 36004.
    It was still working with 36002.
    Any idea what's wrong?
    Is your "auto data window" option enabled in the image format options of the common tab?
    V-Ray for Maya dev team lead
      It doesn't make any difference if it's enabled or disabled.
        Yes I just tested this as well. We'll have to fix it.
          Thank you!
            This fix in V-Ray Next Maya?
            OakCorp Japan - Yuji Yamauchi
            oakcorp.net
            v-ray.jp
              It's not fixed yet, but it should be for V-Ray Next.
              Alex Yolov
              Product Manager
              V-Ray for Maya, Chaos Player
              www.chaos.com
                Has this problem been fixed?
                Fix is ​not found in Release Notes of Next Beta 1 / Beta 2.
                oakcorp.net
                v-ray.jp
                  This should be fixed in Beta 3. I can't find it in the changelog either, it somehow slipped through and didn't make it in the log, but it's fixed and tested.
                  I can't tell right at the moment if it's in beta 2 as well (need to check tomorrow) - but I just double-checked the beta 3 builds and it's working there.
                  We just released beta 3 today, so you should already be able to download the builds from our website.
                  Alex Yolov
                  Product Manager
                  www.chaos.com
                    Thank you for information.
                    Probably because the Data window option was added (Region, Auto, whole), I guess that it was fixed at the same time.
                    oakcorp.net
                    v-ray.jp
                      The data window option determines what will be saved with the render. But we've also made another change where saving from the VFB directly will always save the whole image.
                      Alex Yolov
                      Product Manager
                      www.chaos.com
                        Thank you for the detailed information.
                        oakcorp.net
                        v-ray.jp
                          still not fixed in 36005
                            This didn't make it into 3.60.05, but it will be included in the next update to V-Ray Next. What V-Ray version are you running?
                            Alex Yolov
                            Product Manager
                            www.chaos.com
