V-Ray GPU does not support Opaciy Map connection from filenode's Out Transparency?
  • V-Ray GPU does not support Opaciy Map connection from filenode's Out Transparency?
    If no, it is a very big support defect.
    The user has to change the file configuration with CPU and GPU.
    tested on 3.60.04
    OakCorp Japan - Yuji Yamauchi
    oakcorp.net
    v-ray.jp
    We'll check it out.
      Thanks for the report.
      We fixed it internally for when the nightlies will be back and for the next release.
      If you need this, we can port it in 3.6 so you can use it (way) sooner?
      Best,
      Blago.
      V-Ray fan.
      Looking busy around GPUs ...
      RTX ON
        Thank you.
        I will check Nightlies
        oakcorp.net
        v-ray.jp
          Originally posted by flat View Post
          Thank you.
          I will let you know when it is in the nightlies.
          Best,
          Blago.
          V-Ray fan.
          RTX ON
            Should be fine in the latest stable nightly. If you don't have access to those, please mail to support@chaosgroup.com with link to this thread and they will give you.
            Sorry for the troubles,
            Best,
            Blago.
            V-Ray fan.
            RTX ON
              Thank you for information.
              I already have access to Nightlies.
              oakcorp.net
              v-ray.jp
