I noticed that use the test resolution in Maya's render view doesn't affect V-Ray's render resolution anymore. Is there a way to re-enable that? I don't want to have to change the scene resolution to do lower-res tests. Thanks.
V-Ray doesn't recognize Maya test resolution setting anymore
which V-Ray version do you use? I made a few tests with V-Ray 3.60.04 and it seems to be working fine. However I would recommend you use the test resolution feature that is directly integrated in to the VFB. You can read more about the Test resolution feature in the following link. Let me know if this works for you.
https://docs.chaosgroup.com/display/...Buffer+%7C+VFBLast edited by shaio; 29-05-2018, 06:24 AM.Ivan Shaykov
chaos.com
