Render Setup and physical camera overides
  • Render Setup and physical camera overides
    Hi, i cant seem to get the shutter speed and other attributes to be overridden with mayas render setup. Should this be doable with latest version of vray and maya 2018.2?
    e: info@adriandenne.com
    w: www.adriandenne.com
    It's working fine here. Sometimes you aren't able to drag the attribute to the render setup window, it's often easier to just right click on the shutter speed or whatever you want and create an "absolute override" it will automatically create a collection for the object and attribute and works on just about everything consistently.
      ah...when i created my own collection and added the camera manually, it didn't add it as a shape node, when i did it as you suggested..it worked...thanks for that, much appreciated.
