VRay shader not appear in maya hypershade ?
  • VRay shader not appear in maya hypershade ?
    hi,
    I follow the instruction of "V-Ray for Maya translator SDK" to try to make a simple VRay shader visiable in maya's hypershade but it not works.
    This is my VRay plugin code:
    TexInputTypeTest_VC11.cpp
    Code:
    #include "vrayplugins.h"
    #include "vrayinterface.h"
    #include "vrayrenderer.h"
    #include "vraytexutils.h"
    #include "meshinfobase.h"
    #include "meshinfointerface.h"
    #include "globalnewdelete.cpp"
    // Prevent from "to tchar*" conversion warning ...
    #if (defined __GNUC__) && !(defined __clang__)
    	#pragma GCC diagnostic ignored "-Wwrite-strings"
    #endif //(defined __GNUC__) && !(defined __clang__)
    using namespace VR;
    // Parameters
    struct TexInputTypeTest_Params: VRayParameterListDesc {
        TexInputTypeTest_Params(void) {
            addParamInt("int", 0, -1);
    struct TexInputTypeTest: VRayTexture {
        TexInputTypeTest(VRayPluginDesc *pluginDesc):VRayTexture(pluginDesc) {
            // Set parameter caches
    	paramList->setParamCache("int", &int_val);
        AColor getTexColor(const VRayContext &rc);
        void getTexColorBounds(AColor &cmin, AColor &cmax);
        Vector getColorBumpGradient(const VRayContext &rc);
        virtual PluginInterface* newInterface(InterfaceID id) { return VRayTexture::newInterface(id); }
        // VRayTexture Member function
        PluginBase* getPlugin(void) { return static_cast<PluginBase*>(this); }
        // These pure virtual functions have to be implemented if support RTTexInterface
        //int getDataSize(void) { return 0; }
        //void getData(float *fdata) { }
        //int getSource(const char *part,const char *outParam,const char *lang,VUtils::ShaderSource &, OCLData &mtlData);
        private:
            int int_val;
    #define TexInputTypeTest_PluginID PluginID(LARGE_CONST(2004711829))
    SIMPLE_PLUGIN_LIBRARY(TexInputTypeTest_PluginID, EXT_TEXTURE, "TexInputTypeTest", "Test curious input type of VRay plugin", TexInputTypeTest, TexInputTypeTest_Params);
    AColor TexInputTypeTest::getTexColor(const VRayContext &rc) {
        return AColor(0.0f, 0.0f, 0.0f, 1.0f);
    void TexInputTypeTest::getTexColorBounds(AColor &cmin, AColor &cmax) {
        cmin = AColor(0.0f, 0.0f, 0.0f, 1.0f);
        cmax = AColor(1.0f, 1.0f, 1.0f, 1.0f);
    Vector TexInputTypeTest::getColorBumpGradient(const VRayContext &rc) {
        return Vector(0.0f, 0.0f, 0.0f);
    and the corresponding maya plugin as follows:
    VRayInputTypeTestNode.h
    Code:
    #ifndef _VRayInputTypeTestNode
    #define _VRayInputTypeTestNode
    #include <maya/MPxNode.h>
    #include <maya/MFnNumericAttribute.h>
    #include <maya/MTypeId.h>
    class VRayInputTypeTest : public MPxNode
        public:
            VRayInputTypeTest();
            virtual    ~VRayInputTypeTest();
    	virtual MStatus	compute(const MPlug& plug, MDataBlock& data);
    	static void* creator();
    	static MStatus initialize();
    	static MTypeId id;
    	static MString apiType;
    	static MString classification;
        private:
    	// Input Attributes
            static MObject m_Int;
            // Output Attributes
            static MObject m_OutColor;
    	static MObject m_OutAPIType;
    	static MObject m_OutAPIClassification;
    #endif
    VRayInputTypeTestNode.cpp
    Code:
    #include <maya/MPlug.h>
    #include <maya/MDataBlock.h>
    #include <maya/MDataHandle.h>
    #include <maya/MGlobal.h>
    #include <maya/MFnTypedAttribute.h>
    #include <maya/MFnStringData.h>
    // V-Ray headers
    #include "vraybase.h"
    #include "VRayInputTypeTestNode.h"
    MTypeId     VRayInputTypeTest::id(0x002104F1);
    MString VRayInputTypeTest::classification("shader/surface/utility/:swatch/VRayMtlSwatchGen");
    MObject VRayInputTypeTest::m_Int;
    MObject VRayInputTypeTest::m_OutColor;
    MObject VRayInputTypeTest::m_OutAPIType;
    MObject VRayInputTypeTest::m_OutAPIClassification;
    VRayInputTypeTest::VRayInputTypeTest() {}
    VRayInputTypeTest::~VRayInputTypeTest() {}
    MStatus VRayInputTypeTest::compute( const MPlug& plug, MDataBlock& data )
    	return MS::kSuccess;
    void* VRayInputTypeTest::creator()
    	return new VRayInputTypeTest();
    MStatus VRayInputTypeTest::initialize()
    	MFnNumericAttribute nAttr;
    	MFnTypedAttribute tAttr;
    	MFnStringData strData;
    	MStatus	stat;
    	// Create input attributes
    	m_Int = nAttr.createColor("Int", "mit");
    	CHECK_MSTATUS(nAttr.setKeyable(false));
    	CHECK_MSTATUS(nAttr.setStorable(true));
    	CHECK_MSTATUS(nAttr.setReadable(true));
    	CHECK_MSTATUS(nAttr.setWritable(true));
    	// Create output attributes
    	m_OutColor = nAttr.createColor("OutColor", "oc");
    	CHECK_MSTATUS(nAttr.setStorable(false));
    	CHECK_MSTATUS(nAttr.setWritable(false));
    	//strData.create(VRayInputTypeTest::m_OutAPIType);   // Error ???
    	m_OutAPIType = tAttr.create("OutAPIType", "oat", MFnData::kString, strData.object());
    	CHECK_MSTATUS(tAttr.setStorable(true));
    	CHECK_MSTATUS(tAttr.setKeyable(false));
    	CHECK_MSTATUS(tAttr.setHidden(true));
    	//strData.create(VRayInputTypeTest::m_OutAPIClassification);
    	m_OutAPIClassification = tAttr.create("OutAPIClassification", "oac", MFnData::kString, strData.object());
    	// Add the attributes
    	CHECK_MSTATUS(addAttribute(m_Int));
    	CHECK_MSTATUS(addAttribute(m_OutColor));
    	CHECK_MSTATUS(addAttribute(m_OutAPIType));
    	CHECK_MSTATUS(addAttribute(m_OutAPIClassification));
    pluginMain.cpp
    Code:
    #include "defines.h"
    #ifdef X64
    #define Bits64_
    #endif
    #include <maya/MFnPlugin.h>
    MStatus initializePlugin(MObject obj)
    	MStatus status;
    	MString errStr;
    	MFnPlugin plugin(obj, "Seila", "1.0", "Any");
    	if (!status) {
    		MGlobal::displayInfo("Could not initialize MFnPlugin\n");
    		errStr = "Failed to initialize plugin";
    		status.perror(errStr);
    	// Register the VRayInputTypeTest node
    	const MString classification(VRayInputTypeTest::classification);
    	status = plugin.registerNode("VRayInputTypeTest", VRayInputTypeTest::id, VRayInputTypeTest::creator, VRayInputTypeTest::initialize, MPxNode::kDependNode, &classification);
    	if (!status) {
    		errStr = "RegisterNode failed";
    	return status;
    MStatus uninitializePlugin(MObject obj)
    	MStatus status;
    	MString errStr;
    	MFnPlugin plugin(obj);
    	// Deregister the VRayInputTypeTest node
    	status = plugin.deregisterNode(VRayInputTypeTest::id);
    	if (!status) {
    		status.perror("Deregister Node Failed");
    	return status;
    Both plugins are successfully compiled (with just some warning about DLL exporting) and the produced files are named "vray_TexInputTypeTest.dll" and "VRayInputTypeTest.mll". I put both of them in the same folder and set a desc.txt with content like this:
    Code:
    TexInputTypeTest VRayInputTypeTest {
    "int"                  number       "Int"                 number       INPUT
    ""                     texture      "OutColor"            texture      OUTPUT
    Then set "MAYA_PLUG_IN_PATH" environment variable to the path that plugin files reside. I think that's all i have to do to make my shader appear in maya's hypershade but it not. Do i miss anything ? (I also try to compile the blinn material in the maya plugin example folder but it also not work at all)
    I think the classification string when registering the Maya node is the only one that matters for the hypershade; none of the other files has any relation to that (they are only needed to tell V-Ray what to do). Further on, I think attribute names in Maya are case-sensitive, you can't just type what you want there. The attribute name for the output classification should be "outApiClassification", for the output type "outApiType", for the output color "outColor" etc - exactly like that.
    Next, you need to load the Maya .mll plugin explicitly from Window > Settings/Preferences > Plugin manager (you can set it to auto-load).
    Finally, for the recent versions of V-Ray, there's no need to create a Maya .mll plugin for your shader at all; V-Ray can create hypershade nodes on its own. Check the [vraysdk]\docs\maya_sdk.html file, the section on "Automatic generation of shading nodes".
      Thanks vlado, i can make my shader node visible in hypershade now.
      The next thing I want to do is to make my shader node can accept other types of information rather than just texture color, so i add other type of attributes in my maya node:
      Code:
      MObject VRayInputTypeTest::m_TextureFloat;
      MObject VRayInputTypeTest::m_TextureMatrix;
      MObject VRayInputTypeTest::m_TextureTransform;
      MObject VRayInputTypeTest::m_Material;
      MObject VRayInputTypeTest::m_Geometry;
      	MStatus	stat;
      	m_TextureFloat = nAttr.createColor("TextureFloat", "mtf");
      	m_TextureMatrix = nAttr.createColor("TextureMatrix", "mtm");
      	m_TextureTransform = nAttr.createColor("TextureTransform", "mtt");
      	m_Material = nAttr.createColor("Material", "mm");
      	m_Geometry = nAttr.createColor("Geometry", "mg");
              CHECK_MSTATUS(addAttribute(m_TextureFloat));
      	CHECK_MSTATUS(addAttribute(m_TextureMatrix));
      	CHECK_MSTATUS(addAttribute(m_TextureTransform));
      	CHECK_MSTATUS(addAttribute(m_Material));
      	CHECK_MSTATUS(addAttribute(m_Geometry));
      The VRay plugin node also added with the corresponding attributes:
      Code:
              addParamTextureFloat("texture_float", 0, -1);
              addParamTextureMatrix("texture_matrix");
      	addParamTextureTransform("texture_transform");    // How to make default value of matrix ???
      	addParamPlugin("material", EXT_MATERIAL, -1);
      	addParamPlugin("geometry", EXT_STATIC_GEOM_SOURCE);
      	paramList->setParamCache("texture_float", &texture_float);
      	paramList->setParamCache("texture_matrix", &texture_matrix);
      	paramList->setParamCache("texture_transform", &texture_transform);
      	paramList->setParamCache("material", &materiral_Plugin);
      	paramList->setParamCache("geometry", &geometry_Plugin);
      And desc.txt as follows:
      Code:
      "texture_float"           number       "TextureFloat"            number       INPUT
      "texture_matrix"        transform    "TextureMatrix"          transform    INPUT
      "texture_transform"    transform    "TextureTransform"    transform    INPUT
      "material"                 material      "Material"                  material     INPUT
      "geometry"               uvwgen       "Geometry"                plugin       INPUT
      Although the result node have these attributes in it, it seems they all exposed as texture\color plug such that i can't plug a matrix, material or geometry to corresponding attributes. Does VRay plugin node's inputs are limited to texture\color ? Is it possible to make my shader node to connect with matrix, material ,geometry, volume or light object ? (This is the reason that i want to make corresponding maya node for VRay plugin node, since i suppose auto-generated node just can't recognize output from other type nodes(i.e. mesh or material) without maya node's help)
