Does VRay API provide Du() Dv() functions and dPdu dPdv primitive variables ?
  • Does VRay API provide Du() Dv() functions and dPdu dPdv primitive variables ?
    hi,
    I'm implementing a parallax shader and that has to take use of these functions & variables to calculate the local tangent space of shading point. I just find primitive variables provided by VRay SDK are dPdx and dPdy. Dose VRay SDK provide the functions & primitives mentioned as title ?
    I find that there's a function called "computeTangentVectors" in misc_ray.h but the calculation different from i've ever seen in renderman, i remember in renderman the tangent vectors along s and t are calculated as follows:
    vector along t = Du(t)*dPdu + Dv(t)*dPdv
    vector along s = Du(s)*dPdu + Dv(s)*dPdv
    So the questions about this issus are:
    1. Does the "computeTangentVectors" do exactly the same thing ?
    2. Does this function also work if i pass in a bumped normal vector rather than geometry normal ?
    3. What space should i convert the normal vector to before passing to the function ?
    4. If VRay don't provide infomation such as dv & dv, is it possible to retrieve the area of mircopolygon ?
    No.
    4. is it possible to retrieve the area of mircopolygon ?
    No. V-Ray does not work with micropolygons.
    With that said, in order to get two vectors along the U and V spaces for a specific UVW mapping channel, you can use the following code (keep in mind that internally V-Ray works in (offset) world space):
    Code:
    VR::MappedSurface *mappedSurf=static_cast<VR::MappedSurface*>(GET_INTERFACE(rc.rayresult.sd, EXT_MAPPED_SURFACE));
    if (mappedSurf) {
    	// getLocalUVWTransform() returns a Transform where:
    	// *) The offset contains the UVW coordinates of the shaded point.
    	// *) The matrix portion contains a matrix that transforms differential vectors from
    	// world space to UVW space.
    	VR::Transform tm=mappedSurf->getLocalUVWTransform(rc, -1);
    	// By inverting the matrix, we get a matrix that transforms from differential UVW space
    	// to world space.
    	tm.m.makeInverse0f();
    	VR::Vector along_u=tm.m[0]; // The U direction is the first column of the matrix.
    	VR::Vector along_v=tm.m[1]; // The V direction is the second column of the matrix.
    Let me know if this helps.
