frame buffer color sampler, have it display values for background images as well?
  • frame buffer color sampler, have it display values for background images as well?
    Often times reference images, or background plates are put into the background of the frame buffer, just for visual matching purposes (not actually rendering the background).
    It would be handy if the color sampler would display values for the background, as well as the CG render.
    www.DanielBuck.net - www.My46Willys.com - www.33Chevy.net - www.DNSFail.com
    Thanks for the suggestion. I will add this as a feature request to our system(VMAYA-10877).
    Nikolay Kusht | chaos.com
    Team Lead, 3D Support | contact us
      Yes please! Itd be amazing if there was a way to also set a black point value for example, from the background, and have that applied to the render.
      Website
      https://mangobeard.com/
      Behance
      https://www.behance.net/seandunderdale
        It appears that you could sample the pixels from the Background image, but you need to switch to RGB mode of the pixel sampler. This is because the Background is technically a color correction in the VFB:
          Click image for larger version  Name:	2021-11-26_10-59-55.gif Views:	5 Size:	365.8 KB ID:	1132030
          Oh, thanks Nikolay! I didn't know that! Still getting used to the new frame buffer
