Setting up a velocity AOV seems to be a confusing and vague process. Can we either get a more automated workflow, or better docs for this? Documentation says we should "locate the frame in the sequence that has the most motion". I for one have no idea what this means -- the fastest motion? Is that in camera space or 3D space? The most overall motion? And even if a clear explanation were available, obviously this is often pretty much a wild guess anyway. Busy production artists don't really have time to test render endless frames to get the reading of "Max velocity in last frame" to figure out the highest number. Could you develop a tool that can analyze a sequence and give the highest reading? Or how about at least a means to retrieve this number after a sequence has been rendered, since apparently the renderer can output this on a per frame basis? This way at least we'd know what to punch in here after rendering a shot once (and since almost all shots are rendered more than once this would be a way to get the correct value. The clamping feature is also extremely confusing. Why do I want to turn this on, or not?
Better workflow for velocity passes
are you having problems getting it to work? what program are you comping in? For Nuke, I just leave the velocity options in V-Ray to the default.
Originally posted by Buck View Postare you having problems getting it to work? what program are you comping in? For Nuke, I just leave the velocity options in V-Ray to the default.3D Scenes, Shaders and Courses for V-ray and Corona
NEW V-Ray 5 Metal Shader Bundle (C4D/Max): https://www.3dtutorialandbeyond.com/...ders-cinema4d/
@3drenderandbeyond on social media @3DRnB Twitter
Originally posted by Buck View Postare you having problems getting it to work? what program are you comping in? For Nuke, I just leave the velocity options in V-Ray to the default.But TBH it would be pretty helpful to have some explicit docs about how to work correctly with this AOV and common compositing programs including AE and Nuke, bit depth and color management considerations etc. This all seems to be left to the user to figure out for themselves.
Dmitry Vinnik
Silhouette Images Inc.
ShowReel:
- Likes 1
