small vraySettings node bug?
  • small vraySettings node bug?
    The "Start Frame", "End Frame" and "Frame Step" parameters of the vraySettings node don't get updated when you change those same parameters in the render settings window. However it does render correctly according to what you have in the render settings window. We think this is a small bug and although it isn't very important we think it can be dangerous (for example when scripting custom render tools).
    Cheers,
    Alberto
    www.elranchito.es
    The vraySettings.animation, vraySettings.startFrame, vraySettings.endFrame, vraySettings.frameStep attributes will be deprecated for SP1. V-Ray will instead use the corresponding attributes in defaultRenderGlobals, this way enabling animation in Maya will also enable it in V-Ray, etc. This was needed to make V-Ray work with Backburner in Maya 2010. So that's why the UI is not updated, it's linked to defaultRenderGlobals, not vraySettings.
    Greetings,
    Vladimir Nedev
