Amazing Z Depth Pass
  • Amazing Z Depth Pass
    Stumbled across this shader recently:
    http://www.puppet.tfdv.com/download/shaders_p_e.shtml
    It takes care of all the classic Z depth issues in CG; namely, that you can't accurately blur reflective/refractive objects in post due to traditional Z passes treating everything as solid/lambert materials.
    The way that it breaks Z, Reflect and Refract into R, G and B is truly the icing on the cake. You then blur your Reflect against G, Refract against B and everything else against R.
    If something like this could make its way into VRay somehow, that would be really amazing.
    The best is Zdepth with transparency, refraction, reflection, and glossy support. ^^
    www.deex.info
      Yep and if it's all integrated in VRay, there's no reason it couldn't simply be a set of options you add into a material under "Extra VRay Attributes". That way it looks at your shader's Reflection Gloss and Refraction Gloss for the Z calculations.
      Anyway would just like to say again how amazing this feature would be. It's so key for applying DoF correctly in post.
        Just saw this posted on CGTalk, and he's referring to this:
        http://www.puppet.tfdv.com/download/z_e.shtml
        Someone mentions setting the 'Affect Channels' setting in refraction from 'Colors only' to 'All channels', although I need to test that out to see if it works.
        Red channel - main Z, Green channel - reflection Z, Blue channel - refraction Z
          I don't believe that affects the Zdepth Render Element as I recall.
            So this could be a great new feature to add into vray then
              Refraction to "affect all" affect Zdeph. The probleme is : we need an "affect all" for reflection...
              www.deex.info
                sounds nice! I have a similar request
                VFX Supervisor @ www.parasol-island.com personal website www.dryzen.com latest reel http://vimeo.com/23603917
                  This is the CGT thread I was talking about:
                  http://forums.cgsociety.org/showthre...f=87&t=1017987
                  It looks like TaKIKO has a kind of work around for the moment.
                  'I kinda got the pass by using a blend material and 3 different rgb shaders ex : blue refractive shader +green reflective shader + red zdepth shader...
                  but its a shader based pass which I would think defies the whole purpose of one pass your looking for.'
                  kAzIDamUI:
                  'basically, just 2 things missing :
                  - "affect all channels" in Reflection
                  - zdepth pass spliting diffuse, reflection and refraction as R/G/B.'
                  Any thoughts on this guys ?
                    Now waiting for Vlado to say, it is in the last nightly....
                    Portfolio: http://www.cgifocus.co.uk
                      I can not find the button for reflections
                        Hey, any new about the "affect all channels" in Reflection ?
                        A need this feature for a shot.
                        (Is it on 3dsmax ?)
                        Thank !
                        www.deex.info
                          The "affect all channels" into VRayMtl reflection works great !
                          Now we have relfection and refraction in the Zdepth.
                          Thanks !
                          www.deex.info
                            Now that's a good thing to hear! Hopefully it won't look like crap once comped
                            • #15
                              U want to use refl/refr zdepth as masks for DOF pass?
