Add a Vray attribute to several object/shader.
  • Add a Vray attribute to several object/shader.
    Would it be possible to add a Vray attribute to several selected object or shaders.
    here is where I have a problem:
    I need to add a Multi Matte attribute to several shaders. It would be nice if I could select a couple of shaders, then in the AE, go attribute/Vray/Material ID, and the attribute gets added to every selected shaders. Then I can go and modify it per shaders.
    Thanks,
    Yannick
    You might know already, but this can be accomplished with a couple of lines of mel or python (not including any nodeType checking or error handling):
    // mel:
    for ($mat in `ls -sl`)
    vrayAddAttr $mat vrayColorId;
