In the latest nightly builds the feature to use an alembic file as a vray proxy was introduced.
We are figuring out a workflow to use this feature, because it can be a lot more efficient then our old workflow.
This way you only have to cache your scene once and you don't have to translate your geometry to vrayscene or proxy after you cached your scene to alembic.
Beside a few problems there are also a few features missing, which are needed for us to have a solid workflow.
For instance it is not possible to save the shader assignment in the alembic proxy as with a normal proxy. Right now we export the shader assignment to a separate textfile and assign the shaders to the correct object within the alembic proxy with a script. Only this way we can't assign shaders to faces.
Also the things like object id's and custom attributes are not supported right now.
Will these features eventually be supported? Wouldn't it be a needed to have a separate vray alembic exporter to be able to support these features?
Are there plans to have the vray proxy exporter to export to the alembic format?
greetings,
Arjan
greetings,
Arjan
