enironment fog for ocean..
  • enironment fog for ocean..
    Hi, it be great if there were option to create environment fog for oceans , things like having the fog darker in lower sections of the scene which gradually gets lighter as you get closer to a surface ... sorry if this already exists somewhere !! I did some searches to see if anything like this had already been suggested but didn't find anything. If someone knows a work around please let me know
    kind regards
    ignuf
    Hm, it's not impossible... will think about it.
      You can always do it with the fog attribute in the VrayMtl shader. That's how I always do it. Renders more quickly than full on volumetric fog. Of course, if you really want light scattering you should use env fog (or SSS2).
      Shouldn't you be able to use the ocean mesh as a container for the environment fog if you really want it?
        hi,
        so far I've been using env fog which is doing ok.. but its not convincing enough as yet, so I'll take a look at what you've suggested, thanks Undersky !
        nice demo reel by the way !
        regards
        ignuf
          The ocean water absorbs different wavelength of light differently (i.e. blue is scattered more), which cannot be simulated by the env. fog just yet (but the volumescatterfog can do it).
            Hey Vlado,
            thanks for replying, and for the pointer , i'll check it out , hope all is well
            regards
            ignuf
