triplanar node
  • triplanar node
    would it be possible to get a soft blend triplanar node for vray.?
    that could be really cool.
    http://crunchfx.com/2010/01/17/autom...ction-in-maya/
    https://www.youtube.com/watch?v=EBsaccegYDc
    Isnt that maya node setup pretty much just this?
    http://www.neilblevins.com/cg_educat...projection.htm
    e: i have to start checking which forum i'm in.
      I suppose you can write one in OSL... You can also use the V-Ray multiprojection node, although that one may be a bit difficult to set up and was not really done for that purpose.
        a blended box/ triplanar map would be great.. max too please.. neil's script is really great, i use it all the time, but it involves a plugin or multiple planar maps on each object and is a bit fiddly to set up and keep set up.
          I don't have a all in one "Shader / Node" solution:But I have put together a tri-planar shader that blends due to the camera normals I am doing a video tutorial in the coming weeks for a blended tri-planer network for Maya, it renders quite faster and is great for complex CAD GEO that you don't want to unwrap. Ill keep you posted when the video is done.
          Ashton Woolley
          Senior CGI Generalist
          ASHTONWOOLLEY.COM
            Hi Ashton, just came across this thread while searching triplanar related info for maya. Has this video tutorial ever finished? If so, would be great to learn this technique from you. Thanks!
            always curious...
              i hope we get the triplanar node from vray 3.3..?
                Yes, it's comming.
                V-Ray/PhoenixFD for Maya developer
                  Originally posted by ivaylo.ivanov View Post
                  Yes, it's comming.
                  Great. Look forward to the release and try it out.
                  always curious...
