Hi!
Would it be possible to scale each of the projections individually?
Thanks!
EDIT: My workaround is to just add 2 triplanars together for now.
EDIT2: I just found out that the factor to get the scaling from the 2dPlacement matched in the triplanar node is 0.25 (I bet someone set this up with a checkerboard, which placement defaults to 4
Also we recognized that the node has serious issues with filtered textures. Workaround is to set the filter either to 'off' or to add an extra vray filter attr with 'smooth'. But we'll run into problems with procedural textures that doesn't have any filtering options.
Thanks!
