Texture Switch Similar to switchMaterial
  • Texture Switch Similar to switchMaterial
    I would love to have a texture switch node similar to the switchMTL.... almost the exact same implementation but with switching textures vs materials. This would help in many procedural setups. Right now I have to use condition nodes and stuff... I could use the vrayString variable to switch which works nicely but not really artist friendly.
    Thanks
    Andy
    CG Supervisor\TD A52
    Noted. I've put on a request. Maybe we can implement a new texture for this or expand the multiSubTex to serve the purpose.
    Alex Yolov
    Product Manager
    V-Ray for Maya, Chaos Player
    www.chaos.com
      I think if you add the option for using vrayScalars to the VrayMultiSubTex that would be great. The scalars could just reference the number indicated in the slot.
        Yes, will add that (someone requested it in 3ds Max too).
          Thanks Vlado!
          Andy
            We've expanded the MultiSubTex to work with texture switches (just like the SwitchMaterial does). This is in the nightlies from December 6 and later and will go into the next official release.
            You can use any texture to drive the switch, as well as any values that you put in the switch, including animated values. You can also use user attributes that are passed to the switch to distribute the textures among many objects with the same multiSubTex applied.
            Alex Yolov
            Product Manager
            www.chaos.com
              will the multisubtex be viewable in the viewport at some point?
              e: info@adriandenne.com
              w: www.adriandenne.com
                will it in vray Next.?
                it does not show up in 3.6
                https://linktr.ee/cg_oglu
                Ryzen 5950, Geforce 3060, 128GB ram
                  No, we haven't manage to do it for V-Ray Next and I can't really say when this will be possible.
                  Getting dynamic nodes to work in the viewport is tricky business, even getting some basic previews might have other implications.
                  I'll make a note to discuss it with the devs, though.
                  Alex Yolov
                  Product Manager
                  www.chaos.com
                    Thanks for info. Would it be possible to support it only for the "texture switch" mode?
                    That does only change the state of the texture.
                      We'll get there at some point
                      Alex Yolov
                      Product Manager
                      www.chaos.com
