Render mask override option
  • Render mask override option
    Hey guys,
    Would it be possible to have a render layer override option for "Render mask object set"? Setting an override to enable the "Render Mask" option is great, but not being able to override the assigned set so that multiple layers can produce different masked renders is frustrating.
    My workflow is sometimes Id need car headlights on their own, and also disc brakes from the same beauty. If I add these assets to sets, I cant have render layers for both to render in the same deadline submission as switching out the assigned set isn't overridable .
    Cheers.
    Website
    https://mangobeard.com/
    Behance
    https://www.behance.net/seandunderdale
    Hi and thanks for the suggestion.
    I don't remember why this wan't done at the time, but probably some complications were involved. In any case, I agree that this would make it a bit easier to work with and I'll pass it on to the devs. In the meantime, the objectIDs can already be overriden per layer, so that might be a workaround to use?
    Alex Yolov
    Product Manager
    V-Ray for Maya, Chaos Player
    www.chaos.com
