Is Raw Diffuse Filter supported?
  • Is Raw Diffuse Filter supported?
    I have it enabled in V-Ray Additional Outputs but I'm not getting anything.
    Same for Raw Reflection Filter & Raw Refraction Filter.
    Thanks!
    Hey,
    Thank you for the feedback. Should be nice if you share the screen or scene file. There are a few possibilities of that e.g. GPU rendering or disabled refraction/Reflection material/ textures or Additional Render Element is disabled. Check the scene file again.
    Cheers,
    Boyan Nalchadjiiski | QA Engineer @ Chaos |
    E-mail: boyan.nalchadjiiski@chaos.com
      Thanks Boyan.
      Once I switched my materials from Modo material to V-Ray Material all the passes worked.
      With native Modo materials only a few render elements like Material ID would produce output.
