Vray Glowing Wireframe
  • Vray Glowing Wireframe
    Hi all,
    I'm looking for a way to create glowing wireframes. What I have tried:
    Vray light material with a Vray edges mask (mask is being ignored)
    Have a Vray light material as base and then have a vray material with vray edges as mask above it. (tried every blend mode, the lightmaterial will not show)
    And using the self-illumination color doesn't add actual glow to the wireframe.
    It there a way to do it?
    You can't blend materials of different types using layer/group masks.
    If you want to blend materials of different types, you have to use either a V-Ray Blend material or Shader items.
    I've explained it here : https://forums.chaosgroup.com/forum/...147#post816147
    Anyway, in your case using just a single V-Ray Material with the "vmtl Self-illumination color" effect for the edges texture will probably be sufficient.
    The glow is applied as a post-effect, it can't be part of the render.
    You can access the bloom/glare post effects from the button I've circled in the attached screen-shot.
    Greetings,
    Vladimir Nedev
      thank you, will try it out soon!
