Hi all,
I'm new to Vray for Modo so please bear with me. I like the triplanar mapping feature of Vray. I've been using it as instructed by the user manual by creating a vray material, adding an image map, then adding the triplanar texture. I connect the image map to the triplanar in the schematic, as the instructions say. That all works fine. But how do I get a bump map to work in this setup? I've tried and I can't seem to get it to work. Does it connect to the triplanar in some way? Ideally I just have the bump map do the same thing as the diffuse map but I don't know how it's supposed to fit in there in the shader tree. Thank you in advance. Btw I'm using Modo 14 and the latest version of Vray.
Thanks!
Rusty
Thanks!
Rusty
