Do I use Modo's render output instead of V-Ray's "elements" or are there special V-Ray outputs hidden somewhere? If I use Modo's outputs, what would be the equivalent of "VRayRawReflection" for example?
Modo render outputs/Max render elements
Unfortunately we can't add our own render outputs to modo's shader tree at the moment. I am using whatever render outputs modo has and are supported by V-Ray as well
( with motion vector being a notable exception - it doesn't work currently although V-Ray supports it internally).
I don't think modo has an equivalent for "raw reflection", only "reflection filter" and "reflection".
It is a little bit hidden at the moment but there is a file describing what modo render outputs are supported. It is in your V-Ray for MODO installation folder in "docs\render elements.txt".
Greetings,
Vladimir NedevVantage developer, e-mail: vladimir.nedev@chaos.com , for licensing problems please contact : chaos.com/help
