Render Outputs/Aovs
  • Render Outputs/Aovs
    Was trying render different outputs and just curious which are supported. Was able to use Shaded AA samples but SubSurface did not render out. Also is there a plan to support alpha channels that have been added to Material tags?
    There is a file called "render elements.txt" in the V-Ray for MODO installation folder, in the docs sub-folder.
    It gives some information on what render outputs are supported.
    The sub-surface one is supported but it works only on V-Ray own materials (SSS2 and Skin), because the sub-surface
    part of modo's material is not currently supported in V-Ray.
    Yes, masking alpha render outputs has been requested and we will try to implement it.
    Greetings,
    Vladimir Nedev
