Material Library/Importing V-Ray Materials
  • Material Library/Importing V-Ray Materials
    I'm having trouble getting the MODO materials to look good with V-Ray (Reflections, lighting is not the same as a MODO render.) Should I not be using MODO's material presets? If this is the case, will there be an option to import V-Ray materials or some kind of material database to choose from?
    You can use the presets if they work for you, we will try to improve the support for modo's material even further a bit later on. Currently we are using a different BRDF compared to
    what modo uses, so the highlights/glossy reflections won't match in V-Ray and MODO.
    At some stage we will add the option to import .vrscene files with their materials. Some more complex shading networks from Max/Maya might not work though, I can't promise a perfect conversion.
    Greetings,
    Vladimir Nedev
