Visible Point Lights
  • Visible Point Lights
    Hi guys!
    First of all a Happy New Year to you all!
    Would it be possible to add the "Invisible" and "Affect Reflections" options to point light sources?
    OK, for a default point light with radius zero this doesn't make much sense, but as soon as you turn the point light into a sphere / area light by increasing the radius this would give you a spherical area light that V-Ray usually supports.
    Thanks
    Steffen
    P.S.: I wonder why the MODO renderer doesn't support this feature as well. Maybe I'll post a feature request there, too.
    When you increase the radius of a point light, it doesn't actually become a spherical area light. The soft shadows are just faked.
    My guess is MODO does something similar, and that's why you don't have these options there as well.
    I was going to add a "Make area light" option to the "V-Ray Light" tab for points lights with radius > 0.
    When you check it, the "affect reflections" and "invisble" options will also show up.
    Greetings,
    Vladimir Nedev
      Wow! This sounds like a nice "hack"
      Thanks
      Steffen
        So this option is added for the 2015-03-29 nightly build, as well as for the 3.00.06 open beta build.
        It is called "Make spherical light" in the UI, and is under "Light type specific parameters" in the "V-Ray Light" tab, when a Point light is selected.
        The option itself won't update in RT for now.
        The light's radius, radiance, invisible and affect diffuse/specular/reflections options will update properly.
        Greetings,
        Vladimir Nedev
