Normal map
  • Normal map
    Hello,
    I have a weird issue with the normal map effect in the ST, see below ( 1st is the normal map in Normal effect, 2nd with Bump effect )
    I tried to invert RGB channels but it is worse. Is there a particular way to use normal maps in V-Ray ?
    You most likely need to change the color-space of the normal map to "linear".
    Greetings,
    Vladimir Nedev
      It was that, thank you !
