Hello.
I own MODO, and C4D, but have Vray for C4D at the moment. I understand that Vray is basicly the same across all platforms, and unfortunatly the Vray4C4D forum just is not giving me the support I need, so please bare with me.
Iv reverting to looking at Max, Maya manual as there is non manual for C4D beta v3.3. Im trying to get the best settings for hair, but im getting nowhere. BF.LC is the only thing I know iv got to have set. Other settings that I see being mentioned must be named different as I cant translate what im finding on the net.
I need to know what is the main settings that are responsable for noise, and shapness. I know AA or as its called image sample is for sharpness. Min shading rate of 1 should in theory give me the best render. Sub div min1 max 100, noise 0.005. Can you see anything wrong here?
DMC Sampler, bit sure what this is, and if its even being used, but its set to Adaptive amount 0.85 Min samples 16, noise freshhold 0.005, gllobal sub div multiplyer 1. Iv put light samples to 24, and for the hair object iv got the compositing tag with Mis settings, secondary Rays Multi 0.3
The results im getting is noise, lost of it.
If there is any videos out there on rendering in Vray that will help demystify the settings by example, then please point me in the right direction. At the moment it feels like im totaly alone in figuring Vray out, and am starting to regret that I purchased it.
Thanks Daniel.
Thanks Daniel.
