License question (having an old dongle)
  • License question (having an old dongle)
    I have license question. I have not bought any Modo License yet, but I have a dongle for 3dsmax (however I can't remember which version of Vray).
    Can someone check that at chaos group? And also if I can use that for Vray.
    I haven't used my 3dsmax dongle for 3dsmax since 8 years. So I used it in early alpha of Vray for Modo.
    Also I have no idea if it works on OsX.
    If you haven't used it for 8 years, it's probably for V-Ray 1.5, I think you can upgrade it to 3.x, so it's usable with V-Ray for MODO.
    Check near the bottom of this page : http://www.chaosgroup.com/en/2/vray_licensing.html
    You do get one render node with the V-Ray 3.0 Workstation for MODO purchase, so unless you are going to use DR, you don't need other licenses.
    The dongle should work with OS X, I think.
    It's best to confirm this with support@chaosgroup.com .
    If you give them your chaosgroup.com account name, they will most likely be able to tell you what information they have on your licenses.
    Greetings,
    Vladimir Nedev
