Fur workaround
  • Fur workaround
    Hi all,
    I know that its not possible (yet?) to have fur materials in modo. But is there any workaround. I'm trying to create a rug with long hair.
    any ideas.
    thank you all
    You can use MODO's own fur material with V-Ray by enabling the Use Render Cache option in the V-Ray Preferences.
    The tool-tip of the option will tell you what other geometry it enables.
    Greetings,
    Vladimir Nedev
      Thank you, I'll give it a try see how it works
        Im having trouble rendering my modo fur in Vray - message above says enable render cache - I'm on 902 and there is no check box . . where did it go?
          Sorry, the information in my previous post is not up-to-date.
          The setting was moved to the Render item and is now saved with the .lxo scene, it is no longer a global preference.
          See attached screen-shot.
          Greetings,
          Vladimir Nedev
