How do I turn off the info in the render region?
  • How do I turn off the info in the render region?
    Some how enabled this, but can't find in the manual how to disable it.
Name:	Vray region info.PNG
    How do turn it off?
    Thanks in advance- I'm sure it's right there in the manual and I'm just missing it.
    No worries- Jonathan Josenhans showed me it was in the prefs. Not sure how I turned it on, but there it is. Is there a way to not have it in the region but have it otherwise? Must investigate!
      'Show statistics in VFB' under Preferences -> V-Ray Renderer -> V-Ray RT Rendering.
      Edit: I see you found while I had this open
        The weird thing is I have no idea how this was switched on as I hadn't actually touched the preferences section. Maybe you can enable/disable it else where too?
          For me it's switched on by default. I just completely reinstalled my system (Windows 7 -> 10) and all my software. V-Ray definitely had the statistics without doing anything. I haven't seen the option to toggle it anywhere else, but perhaps it's possible...
            Yes, this option is enabled by default.
            Greetings,
            Vladimir Nedev
