I have to render around 20 different views so manually starting and saving would be a pain.
Since the "Render Passes" doesn't work yet in V-Ray for MODO I was looking for a workaround.
At the moment I'm using the "Render with Standalone"-Option with "delete .vrscene after rendering unchecked.
I then cancel the render, once it starts and i have a nice .vrscene-file as well as a .bat file with all the options included DR.
I then create these two files for all my passes and at the end i created a .bat file including all the .bat files saved before and let my computers do the rest. Works better than with Deadline, since I'm not rendering an animation and I'm using DR for these stills.
It would be nice if "Render with Standalone" would have some additional options like "just export" and a "export .bat" option as well as the possibility to give you .vrscene-file a name. At the moment you can only define the save location (browse-button would be nice) and it gives you scene-file some cryptical name.
