Output pattern - final color output
  • Output pattern - final color output
    I just noticed that the output pattern isn't respected for the beauty render (final color). Is this by design or bug? See attached image.
    The output pattern set to: .[<output>].<FFFF>
    I would expect the rendered file to be called robot.beauty.0001.exr.
    Any workarounds?
    * I'm rendering animations.
    For the moment I m not sure final color ouput is render in vray. It's rgb color in vray vfb.
    When you save in modo stand alone you give a name. Rgb color take this name. Isn't it?
    I wonder how to choose the render elements output by default in Vray. I just know how to add elements
      Yes "Final Color Output" = "RGB Color".
      You can't change the name in V-Ray at the moment.
      Yes, it's ignored for now, need to fix it eventually.
      Greetings,
      Vladimir Nedev
        Output pattern final color output
        Hi all,
        Is the any 4 output video board similar to ATI FireProTM V9800 that can be used on mac?
        Alex
        porady prawne Gdańsk
