RT Final Render
  • RT Final Render
    Hi guys,
    Is it possible to use RT as my final render set to progressive. In modo I use the preview as final render but I go into my GI, channels etc to get a high quality render. I use the method that Richard Yot shows in his Texturing masterclass.
    1- Would I have to fiddle around like I do in modo to get a high quality preview render in Vray RT?
    2 - Does the RT render out at the specified render image size I have set in my final render output?
    Thanks for your advice.
    1. In some cases you might want to further decrease the noise threshold for the RT render:
    2. By default it fits the image inside the VFB window. Just untick this option to make it render at full resolution:
    Note: RT rendering is setup for fast initial feedback, it won't be as efficient as Production rendering.
    I haven't tested it, but I am pretty sure RT will take more time to reach the same noise threshold compared to Adaptive/Progressive final rendering.
    Greetings,
    Vladimir Nedev
      Thats Great Thank you
