Animated Hair still busted?
  • Animated Hair still busted?
    I coulda swore I did a test a couple months ago using the fur/hair shader on a animated deforming body and it worked....guess not? I did a quick test today and it's still not working. Any word on whether or not rendering an animation with fur will work in the future?
    I'm just using Modo fur for the hair and the eyelashes along with the VRay hair material.
    Here's a link to the thread on the Modo forums, it has a video example.
    http://community.foundry.com/discuss...age=12#1075401
    I haven't fixed it yet. Sorry about that. There is no way it worked.
    Hopefully I will get to fixing it in the future, but can't make promises as to when.
    Greetings,
    Vladimir Nedev
      Animation and motion blur on MODO fur geometry is possible in tomorrow's nightly build ( 2017.06.10 ).
      You need to explicitly enable it, as it will increase .vrscene file size significantly if the .vrscene is exported for animation (e.g. animation rendering with DR).
      See attached image.
      Greetings,
      Vladimir Nedev
        Vlad,
        You rock! Thanks!
        Posted a link with an example on the Modo boards:
        http://community.foundry.com/discuss...hair-fur-fixed
