How to set the file name string for output by standalone?
  • How to set the file name string for output by standalone?
    Is there a way to specify how the frame # appears in a render?
    For instance instead of:
    Animation.RGB_color_denoise_0001.exr
    How do I get:
    Animation_RGB_color_denoise_0001.exr
    It's not possible at the moment. Support for MODO's Output Pattern (the one in the Frame tab on the Render item) is on the TODO list.
    Greetings,
    Vladimir Nedev
      OK, that will be good. AE is horrible at figuring out file names, so I'm having to rename my renders with a batch utility.
