Render Elements
  • Render Elements
    Hi Vlado,
    I have an issue on the render elements.
    I don't have the full list in my Vray
    Left my render element / Right the list on the guidebook
    Thks a lot
    And I tried to click on the small arrow on the bottom left side but can't succeed
    This seems to be an issue with the "attr.formPopover" command that I am using in MODO 901, 902 and 10.0 to open the sheet. The issue is present only in those MODO versions.
    It seems you can't tell the command what the height of the window should be, it computes it on its own but not accurately.
    Which MODO version are you using ?
    You can always create the missing render elements manually from the Add Layer -> Render Outputs menu in the Shader Tree, like you would in MODO without V-Ray.
    Greetings,
    Vladimir Nedev
      Ok if I can do it manually it's ok,
      One mote question. Does the render pass is enable en GPU? To only render Specular and refraction?
      The missing one for me?
        I will probably remove the ability to pin the render elements form in MODO 901, 902 and 10.0v1, this should fix the issue with the parts of the UI that are not visible.
        Yes, I think the specular and refraction elements are supported by RT GPU.
        For a full list of supported render elements in RT GPU, you can check out this page : https://docs.chaosgroup.com/display/...RenderElements
        Greetings,
        Vladimir Nedev
