Set Material ID .... where is it ?
  • Set Material ID .... where is it ?
    can anybody help me, where to set the Material-ID ?
    In "open lens effects setting" it is possible to mask the Bloom Effect with an Object - or Material ID.
    Where do I find the Material ID ?
    Cheers
    Alex
    Hey Agental,
    Thank you for the post. Well, I've made a simple video with steps to recreate the desired result.
    https://my.pcloud.com/publink/show?c...JIdYBWT5FUnP2X
    Cheers,
    Boyan Nalchadjiiski | QA Engineer @ Chaos |
    E-mail: boyan.nalchadjiiski@chaos.com
      Hi Boya,
      thank you for the quick response but I was looking for "Material ID", the field under "Object ID" in your Screenshot.
      Thanks
      Alex
        Originally posted by agental View Post
        Hi Boya,
        Thanks
        Alex
        It's not possible at the moment. We don't have the material ID render element in MODO yet.
        For per-material masks you can use the "surface ID" render element or per-material alpha render elements, but those can't be used with the lens effects.
        Greetings,
        Vladimir Nedev
          Hi Vladimir,
          thanks for clarification .... I hope, sometime it will be implemented
          Big praise, you guys are really fast in the answer !!!
          Thanks
          Alex
            There is "Material ID (color)" in The V-Ray Additional Outputs of V-RayMODO 3.6, but still not supporting it?
            OakCorp Japan - Yuji Yamauchi
            oakcorp.net
            v-ray.jp
              No, it is now supported. With the addition of that output, we also added a way to specify it in the material group item. See screen-shot.
              There is a bug right now, where you need to set the multimatte ID to something other than 0 to have the material ID color work, but we will fix it.
              For the lens effect mask, you have to use the multimatte ID, i.e. the integer number.
              Greetings,
              Vladimir Nedev
                Thank you for information! (and bug)
                Added V-Ray property to material group item.
                I've learned
                oakcorp.net
                v-ray.jp
                  Greetings,
                  Vladimir Nedev
                  I just came across this, great stuff!
