Setup for Substance Painter please
  • Setup for Substance Painter please
    Hi Im new to both Vray and Substance painter. Iv used the preset in substance for vray have the textures, where do I put them please?
    Thanks
    Dave
    Hey, Dave,
    Well, you can use Substance export preset for Modo, Unreal, Unity, and V-Ray as well. Check the compatibility page as well: https://docs.chaosgroup.com/pages/vi...+Compatibility
Name:	Screenshot 2018-03-23 11.19.37.jpg
    Boyan Nalchadjiiski | QA Engineer @ Chaos |
    E-mail: boyan.nalchadjiiski@chaos.com
      Hello
      I have the textures already, maybe I should have explainned. I need to know where each map goes in order to get it to look right?
      Dave
        You mean this? -> https://support.allegorithmic.com/do...V-Ray+for+Maya
        Its the setup for Maya, but applies to Modo as well. Export from Substance Painter using the Vray preset, then set the texture effect of each texture in Modo (standard Vray material):
        Diffuse -> vmtl Diffuse Color
        Reflection -> vmtl Reflection Color
        Glossiness -> vmtl Reflection Glossiness
        IOR -> vmtl Fresnel IOR
        Normal -> Normal
          You can also set the Diffuse texture to have Modo's own "Diffuse Color" effect.
          This will also work with V-Ray's material, but will additionally be visible in Modo's OpenGL viewport.
          Greetings,
          Vladimir Nedev
            If you want to speed up the workflow you can check my substance painter live link, now it works with vray in modo, max and maya! https://gumroad.com/xolotlstudio
