Default Render Settings
  • Default Render Settings
    I have been tinkering with the default settings and I think I may have set something too higher, cause my rendering is slow. Is there an easy way to reset VRay defaults for the entire Plug in? I wish there were some saved presets for each important parameter that indicates a low medium high range to give the user some idea of what to be careful with. Even some better tooltips could help.
    If you just want to reset specific values, you can do it using the standard modo way: Right click a channel label > remove all
    If you would like to reset the entire render item, select it, then go to top menu > add/remove vray packages > remove vray render settings from selected render item
    Win10 Pro 64 / AMD Ryzen 9 5950X / 128GB / RTX 3090 + 1080 Ti / MODO
    I am the resurrection, and the life: he that believeth in me, though he were dead, yet shall he live - Jesus Christ
      I am really happy to see this analogy, it reminds me old fashion days of Luxology forum.
      Thx Funk.
      Cheers,
      Boyan Nalchadjiiski | QA Engineer @ Chaos |
      E-mail: boyan.nalchadjiiski@chaos.com
        Howdy Funk! Thanks for the suggestion. I assume that after removing the package, I add it back again and the defaults will be reset?
          The package will be added back automatically once you deselect and reselect the render item
